Step-By-Step Tutorials
The purpose of this chapter is to demonstrate the capabilities of CUBIT for finite element mesh generation as well as provide a brief tutorial on the use of the software package. This chapter is designed to demonstrate step-by-step instructions for generating a simple mesh on a perforated brick.The following activity demonstrates the basics of using CUBIT to generate and mesh a geometry. By following these steps, you will become familiar with the basics of the command-line and GUI interfaces without stopping for detailed explanations. All the commands introduced in this tutorial are documented in subsequent chapters on this manual.
Here are a few tips for the examples in the tutorial:
- Focus on the instructions preceded with "Step" numbers. These walk you through a series of explicit activities that describe how to complete the task.
- Refer to the screen shots and other pictures that show what you should see on your own monitor as you progress through the tutorial.
- In this tutorial, command line options will look like this:
cubit> <Your commands go here>
If you do not have the Graphical User Interface (GUI) version of CUBIT, follow the steps in the right column below, otherwise, proceed through the steps on the left:
| GUI | CL | |
| Overview | Overview | |
| Step 1 | Step 1 | Beginning Execution |
| Step 2 | Step 2 | Creating the Brick |
| Step 3 | Step 3 | Creating the Cylinder |
| Step 4 | Step 4 | Adjusting the Graphics Display |
| Step 5 | Step 5 | Forming the Hole |
| Step 6 | Step 6 | Setting Interval Sizes |
| Step 7 | Step 7 | Surface Meshing |
| Step 8 | Step 8 | Volume Meshing |
| Step 9 | Step 9 | Inspecting the Model |
| Step 10 | Step 10 | Defining Boundary Conditions |
| Step 11 | Step 11 | Exporting the Mesh |
Additional Tutorials
ITEM Tutorial - A tutorial on the new ITEM wizard.
Power Tools GUI Tutorial - A tutorial on geometry decomposition and cleanup using the Power Tools on the new CUBIT GUI.
Decomposition Tutorial - A series of webcutting hints and suggestions for creating sweepable volumes on various models.
Geometry Cleanup Process Flow - A flowchart on geometry cleanup and defeaturing.
