CL Basic Tutorial Step 3
Step 3: Creating the Cylinder
Now you must form the cylinder which will be used to cut the hole from the brick. This is accomplished with the command:
cubit> create cylinder height 12 radius 3
At this point you will see both a brick and a cylinder appear in the CUBIT display window, as shown below:
Brick and Cylinder
