GUI Basic Tutorial Step 11
Step 11: Exporting the Mesh
Finally, the mesh needs to be written to an Exodus II file. This is easily done:
- From the File menu, select Export.
- Set the file export type to Genesis Files from file type combo box.
- Enter a file name in the dialog, such as brick_with_hole.g, and select Save. Since this is a standard file management dialog, the user may browse or use any other file management functionality supported by the platform.
- Select the Export All check box
- Select Finish to export the mesh.
