Release Notes for Coreform Cubit 2023.11
Coreform is pleased to announce Coreform Cubit 2023.11, which features many new capabilities and improvements improving support for nuclear energy applications. Enhancements include an exporter to the DAGMC radiation transport code, improvements to the ABAQUS export to support the MCNP radiation transport code, as well as an MCNP importer that reconstructs MCNP models within Coreform Cubit. A new coarse trimesher setting was added to support producing meshes for radiation transport codes used within the nuclear energy industry. (Download Coreform Cubit here.)
Released: 2 November 2023
Table of Contents
Support for Radiation Transport Codes
DAGMC Export
Direct Accelerated Geometry Monte Carlo (DAGMC) is a software package that allows users to perform Monte Carlo radiation transport directly on CAD models. The DAGMC community previously developed a Coreform Cubit plugin. Coreform Cubit now contains native capability to export DAGMC .h5m files. Users familiar with the original DAGMC plugin will now use Coreform Cubit’s native Exodus-based workflows for assigning materials and/or boundary conditions (i.e., block, sideset, nodeset) rather than the group-based workflow implemented within the original plugin.
Export cf_dagmc <'filename'> overwrite
A tokamak-style nuclear fusion reactor, meshed in Coreform Cubit using the new coarse trimesh setting, and ready for export to DAGMC.
For more information see: Exporting DAGMC
    MCNP Import
    The Monte Carlo N-Particle® (MCNP®) code, developed by Los Alamos National Laboratory, can be used for general-purpose transport of many particles including neutrons, photons, electrons, ions, and many other elementary particles, up to 1 TeV/nucleon. The transport of these particles is through a three-dimensional representation of materials defined in a constructive solid geometry, bounded by first-, second-, and fourth-degree user-defined surfaces. In addition, external structured and unstructured meshes can be used to define the problem geometry in a hybrid mode by embedding a mesh within a constructive solid geometry cell, providing an alternate path to defining complex geometry.
    Coreform Cubit now provides a method for importing MCNP files. The standard MCNP file has a .i extension. This file format contains Constructive Solid Geometry (CSG) models. These models are converted into Boundary Representation (B-Rep) files using the ACIS modeling engine.
    import cf_mcnp <'filename'> [verbose] [debug] [debug_output] [debug_input] [extra_effort] [skip_mats] [skip_merge] [skip_imps] [skip_nums]  [skip_graveyard] [skip_imprint] [uwuw_names] [tol <specific tolerance>]
    For more information see: Importing MCNP
      Improved assembly support when exporting to ABAQUS / MCNP
      Various enhancements made to ABAQUS export include writing additional element sets and node sets based on groups, specifying coordinate frames, and new ‘instance_per_block’ option. These additions will streamline using Coreform Cubit with MCNP.
      • Write additional element sets and node sets based on groups
      • Documentation improved for specifying coordinate frames
      • A new instance_per_block option was added for automatic part instancing based on defined blocks
      For more information see: Exporting ABAQUS
        Geometry
        Simplification of merged surfaces now supported
        The simplify command for compositing surfaces now supports merged surfaces in addition to external surfaces.
        For more information see: Simplify Geometry
          Improved behavior for splitting surfaces
          Coreform Cubit’s previous ability to split fillet surfaces was not ideal, creating a split that looked like a projection of a linear curve. The splitting routine was fixed so that the split follows the curvature of the surface, creating a more expected and ideal result.
          (a) Previous split, (b) New, improved split.
          For more information see: Split Surface
            New Reduce Bolt Patch command
            The new Reduce Bolt Patch command in Coreform Cubit offers an alternative method for representing bolts in simulations. It replaces bolt geometry with concentric circular surfaces imprinted on the model, centered on the bolt axis. Sidesets are automatically applied to these surfaces, representing preload forces for analysis purposes. By default, the command utilizes the Shigley frustum to determine the radius of the sideset patches, but the desired radii can also be directly designated. Additionally, the resulting patches can be meshed using this command, and sidesets can be customized with incremental IDs and names.
            Two bolts showing before and after the reduce bolt patch command was applied.
            The reduce bolt patch command is one of several options for reducing fastener geometry for use in analysis. This option has also been added to the geometry power tool machine learning tools for classifying geometry. When designated as a bolt, additional solution options are presented that now include the reduce bolt patch command.
            A new command panel for setting up and previewing options for the reduce bolt patch comand can be accessed from Geometry->Modify->Volume->Reduce->Bolt Patch
            (a) New Reduce Bolt Patch GUI panel (b) Geometry Power Tool, machine learning Classify Parts diagnostic used to identify bolts. New power tool solutions for bolts include reduce bolt patch command.
            For more information see: Reduce Bolt Patch
              Meshing
              Coarse mesh setting for trimesh scheme
              While meshing is most commonly seen as an operation for PDE-based simulations that require high-quality regular-shaped elements for accuracy, there are tangential industry applications that also utilize mesh datastructures in their workflows. Examples of these include additive manufacturing (slice generation) and nuclear energy (Monte Carlo particle transport). These applications typically resolve the geometry to high-accuracy through the use of a minimal number of high aspect-ratio triangles. To support these applications Coreform Cubit now supports a coarse setting in the trimesh scheme. This allows users to visualize the mesh prior to export (e.g., to STL, DAGMC ) as well as produce different density meshes on different geometric entities (as opposed to a global parameter set on export) and otherwise access the full utility of Coreform Cubit when producing their meshes.
              [Set] Trimesher Coarse {on|OFF [<ratio=100.0> <angle=5.0>]}
              (left) Default trimesh settings, (right) New, coarse option with default settings.
              For more information see: Trimesh
              Improved robustness of triangle meshing
              Triangle meshing robustness is improved and a correct mesh can now be produced in a few specific combinations of compositing and merging surfaces. Additionally, on some CAD models, triangle meshing would fail due to low precision geometric evaluations. These failures were a regression introduced in a previous version of Coreform Cubit from improving performance. Geometric evaluations were enhanced to retain some performance and re-establish robustness.
              Improved robustness of node equivalencing
              Equivalencing nodes is now more robust after importing multiple mesh files as free mesh. Additionally, higher order nodes are now equivalenced when they exist. Performance has been improved allowing the equivalence operation to complete quicker on larger models.
              For more information see: Merging a Free Mesh
              Updated Sculpt Command Syntax
              Previously, the sculpt command could be executed without arguments, utilizing the current volumes as the default target geometry for meshing. However, to accommodate various file types (e.g., STL, diatom, microstructures) containing geometry, the sculpt command now requires the designation of the target geometry as the first argument when invoking the command.
              For more information see: Sculpt
              Midnode correction on mesh-based geometry
              Coreform Cubit previously performed automatic midnode correction during the import mesh geometry command, enhancing the quality of high-order tetrahedral elements (TET10) by straightening edges when quality was below a designated threshold. Users can now toggle the midnode_correction option during import, allowing control over this capability. By default, midnodes will not be corrected based on quality.
              For more information see: Midnode Correction
              Graphical User Interface
              New right-click automatic surface selection options
              After selecting two surfaces (or collections of surfaces), a new right-click select between option selects all surfaces between the two already selected surfaces, given there is only a single path of surfaces between them. Merged surfaces are skipped over. If a single surface is selected, the new select enclosure option will select all connected surfaces, forming a water-tight enclosure.
              For more information see: Right Click Commands for the GUI Graphics Window
              Python Interface Enhancements
              New Methods
              • get_connected_surfaces()
                • Given a surface, returns all connected, unmerged surfaces.
              • get_bolt_shigley_radius()
                • Determines the effective load radius surrounding a bolt based on the diameter of the head and the upper and lower volume thicknesses based on Shigley.
              Deprecated Methods
              • get_displacement_coord_system()
              Cubit bug fixes and enhancements
              Improved OpenMPI version compatibility
              When running Sculpt on Linux and macOS, the version of OpenMPI used is no longer restricted to version 4.0. One may use any version of OpenMPI which is ABI compatible with version 4.0. This includes 3.0, 3.1, 4.1 and 5.0. Running Sculpt with other versions of OpenMPI may be useful if targeting a specific hardware which the distribution-included OpenMPI doesn’t support.
              New extended parsing options with blocks, nodesets and sidesets
              Extended parsing of blocks, nodesets and sidesets in mesh is now fully supported. For example, one can get sidesets using a sideset in face 40 syntax or get blocks using a block in hex 32 syntax. This feature now works whether the blocks, sidesets or nodesets are defined by geometry or mesh. This may be useful when writing general commands to work on both types of definitions.
              Generalized coordinate frame commands
              The syntax for creating coordinate frames has been updated to no longer include the word exodus. The is change is to emphasize that coordinate frames are available for use with ABAQUS as well as EXODUS. Old journal files will continue to work when using the word exodus.
              For more information see: Coordinate Frames
              New string option in locate command
              The following locate commands now support an optional string parameter allowing customization of the displayed label. The supplied string is used as the label instead of the default xyz position or name of the entity, as shown below.
              locate location [<string>]
              locate [geometry] [genesis_entity] [bc_entity] [contact pair] [node] [element] [<string>]
              Location using: locate vertex 1 'my_text_here' and locate vertex 5
              For more information see: Drawing, Locating, and Highlighting Entities
              Defects Fixed in Coreform Cubit 2023.11
              Ref # Description
              MESH-4178 SHOW option in GUI not echoing info to command line
              MESH-5135 Refine in Sculpt based on geometry id
              MESH-5465 Review and add unsupported sculpt options to the GUI
              MESH-5539 Coreform Cubit export to MCNP (ABAQUS)
              MESH-5630 Equation-Controlled Distribution Factors broken since 15.0
              MESH-5642 Deploy the latest version of Verdict on https://github.com/sandialabs/verdict
              MESH-6328 Change package layout to comply with mac format
              MESH-6585 Failure in blunt tangency operation
              MESH-6740 Long term support of SGM python scripts
              MESH-6934 Upgrade gtest for SGM, UMR and Coreform Cubit
              MESH-6957 Align command doesn’t work with surf
              MESH-6961 Graphics curves bleed through solid
              MESH-6971 Mpiexec issue with sculpt
              MESH-7102 Sideset X add – weird ERROR message
              MESH-7104 Align not working
              MESH-7124 Update abaqus export to support mcnp
              MESH-7126 Why is sculpt getting called in my Coreform Cubit journal workflow
              MESH-7128 Support sideset in face
              MESH-7132 Better cavity selection
              MESH-7133 View in True hidden line mode and view in hidden line mode are the same?
              MESH-7140 Sculpt meshing from SPN file
              MESH-7252 Volume Id not being honored in individual .cub files with multiple import cubit commands
              MESH-7254 Sculpt to output memory usage between refinement
              MESH-7271 Buggy connected_sets option in ‘remove surface’ command
              MESH-7276 Listing Error in Aprepro Loop
              MESH-7307 Webcut with general plane case not working
              MESH-7310 Meshing “simple” domain
              MESH-7313 Split surface not working
              MESH-7314 Higher order nodes not equivalenced
              MESH-7315 Surface normal inconsistent through merge operation & trimeshing
              MESH-7320 Import SGM moves part
              MESH-7321 Split surface not working great
              Re-enable equiangle skew quality measure for wedges
              Add missing volume webcuts to entity-based navigation
