Background
Led by Dr. G. Ivan Maldonado, the Neutronics Research Group at the University of Tennessee advances the study of nuclear reactors across fusion and fission systems, spanning reactor physics, in‑core fuel management, radiation shielding, fuel‑cycle analysis, and materials science to improve safety, efficiency, and sustainability. Within the realm of fusion systems, the team assessed post‑operation radioactivity in a tokamak‑based fusion facility to predict dose‑rate levels and their spatial distribution—insights that support safe worker access, maintenance scheduling, and design optimization over the facility lifecycle. Finite‑element–quality meshes generated in Coreform Cubit preserve exact CAD geometry and enable robust transport and photon decay source‑sampling steps, producing reliable, reproducible dose‑rate results. For representative studies, see the group’s publications.
Fig 1: Exact CAD rendering of the FNSF fusion device, highlighting the tight clearances among components that make an exact‑geometry, overlap‑free workflow is essential. Image courtesy of Fusion Neutronics Science Facility – FNSF.
Problem
The SonicEdge design team needed to simulate a multi-membrane speaker in which several thin, vibrating layers couple through air gaps. The device geometry involved extremely small features and close tolerances, making it difficult to achieve conforming solid-fluid meshes that aligned precisely across all interfaces. Accurate simulations demand robust, parametric geometry, high-quality conforming meshes so that interfaces between membranes and air align perfectly, and seamless multiphysics hand-off to downstream solvers. Because small inaccuracies at the interfaces can lead to numerical instabilities or degraded performance predictions, SonicEdge needed a preprocessing environment capable of generating precise, repeatable meshes that could be easily updated for rapid design iteration.
Fig 2: Triangulated STL surface exaggerates curvature and wall thickness versus exact CAD, illustrating how faceting errors can create artificial overlaps in tightly packed assemblies. (Source: https://en.wikipedia.org/wiki/STL_(file_format) )
Accurate source sampling further requires confining decay‑photon sources to actual activated materials; using a global sampling volume can trigger excessive sampling rejections or prematurely terminated runs. The project therefore needed a workflow that preserved exact CAD geometry, avoided overlaps, and produced unstructured volumetric meshes suitable for transport calculations and decay‑photon source sampling—without inflating problem size or uncertainty.
In a tokamak design, many components are very close to each other; thus, overestimating the triangulation can cause overlap between components.
Fig 3: Exact CAD (left) versus STL representation (right) of the same device. Faceting thickens curved parts and can create interferences; maintaining exact CAD in the workflow avoids these errors.
Solution
Coreform Cubit provided a geometry‑faithful, mesh‑centric environment that connects CAD to radiation transport without loss of fidelity. The team exported exact‑geometry models directly to DAGMC for transport and generated unstructured volumetric meshes in Exodus format for decay‑photon source sampling. Cubit’s interference checks and Boolean repair resolved near‑contact overlaps. Webcut partitioned the geometry into logical regions, and local mesh sizing placed elements where transport accuracy demanded them. A Python‑driven workflow associated each meshed component with its material, decay energy, and intensity so that sources were sampled only within activated volumes and automatically excluded from voids. Together, these steps reduced lost particles from overlap regions, lowered uncertainty compared to STL‑based geometry, and yielded solver‑ready meshes purpose‑built for neutron transport and the R2S decay‑photon step of the OpenMC code.
Fig 4: Partitioning the CAD with Webcut and applying local mesh sizing in Coreform Cubit to create well‑defined regions and element densities tailored to transport and source-sampling needs.
Results
Fig 5: Global sampling (left) pushes most samples into void, driving reject sampling and instability. Mesh‑based sampling from Exodus (right) confines sources to activated materials with correct energies and intensities, producing stable, physically faithful dose‑rate maps.
Conclusion
By preserving exact CAD geometries, eliminating overlaps, and automating exports to DAGMC and Exodus, Coreform Cubit supplied the reliable, reproducible meshing foundation the fusion neutronics research required. The result is a robust, scriptable pipeline from CAD to transport and decay‑photon source sampling, supporting confident dose‑rate predictions for complex tokamak systems.
