Release Notes for Coreform Cubit 2020.2
(Download Coreform Cubit here.)
Released: 10 November 2020
Table of Contents
Summary
This is the first release of the Coreform Cubit branding of our meshing software, which was formerly known as Trelis.
    Graphical User Interface
    New Geometry Power Tool Diagnostics and Solutions
    The Geometry power tool includes interactive diagnostics and solutions for defeaturing and repairing CAD models. New diagnostic tests have been added along with rapid solutions for repair. Updated and expanded diagnostics categories include Traits and Assembly Checks.
    • Traits- This category includes tests for common surface configurations in a geometric volume. This release introduces new and improved Traits diagnostic tests:
      • New Holes and Chamfer Chains diagnostics tests allow for rapid identification of these common characteristics so users can quickly remove or verify them. These tests identify sorted lists of collections of surfaces that can be expanded and visualized. Collections of Holes and Chamfer chains are sorted by radius and thickness respectively. New associated context solutions also provide for fast removal of selected collections of surfaces.
      • The Blend Chains diagnostic test replaces the Blends diagnostic. Blend Chains now identifies sorted collections of blends that are associated with the same blend chain. This allows rapid identification and removal with a single command.
    • Assembly Checks- The new Assembly Checks category of diagnostic replaces Overlap Checks. It consolidates all diagnostics for checking interactions between volumes in an assembly into one category and adds additional valuable tools for resolving issues prior to imprinting, merging and meshing.
      • The new Volume Gaps test will display pairs of volumes that are not touching but are closer than the Volume Gap threshold.
      • Volume Overlaps is now updated to generate contextual simplified solutions for removing overlaps between pairs of volumes.
      • The new Volume Misalignments diagnostic test will identify volumes that are touching but have entities that would otherwise create slivers when imprinting. This also includes new capabilities for quickly visualizing and resolving misalignments between volumes.
      • Volume Contacts replaces the Overlapping Surfaces diagnostic. It identifies volume pairs that are touching, but have not been merged along with their overlapping surfaces.
      • The new Mergeable Geometry diagnostic replaces the individual vertex, curve and surface mergeable categories. This diagnostic includes entities that are coincident and can be merged.
      • A new option for specifying Tolerant Imprint and estimating an Imprint Tolerance is now provided. Changing the Imprint Tolerance can change the results of the Gap, Overlap and Misalignment diagnostic results.
      New Command Panel Navigation Method
      A new, optional, method for navigating the command panels has been added. This new option can be toggled on and off under Tools/Options/Command Panels. The obvious benefit of using this ‘breadcrumb’ navigation method is gaining additional vertical space for command panels which will eliminate the need for scrolling in many cases.
        Support for Dark Mode
        Support for Dark Mode has been added to Cubit 2020.2.
          Display Volume Overlaps and Neighbors from Context Menu
          Two new options are available in the graphics window when volumes are selected:
          • Draw Nearby Volumes - All volumes close to the selected volume(s) will also be drawn. This is useful when working with large assemblies to view only local parts for defeaturing or boundary condition assignment.
          • Draw Volume Overlaps - Draws the wireframe representation of the selected volume(s) and any volumes it overlaps. The overlapping region shared by the volumes will be displayed in red
            Tetmesh and Trimesh GUI Command Panels
            A new command panel for setting options for the tetmesh scheme is now available supporting all new local and global options for tetrahedral meshing. This panel now includes two separate tabs for setting options for surface meshing and volume mesh options. The trimesh panel has also been updated in a similar manner for setting options for the trimesh scheme.
              Reduce Bolts Command Panel
              The new Reduce command (described below) uses a new command panel to rapidly set up parameters to simplify and assign boundary conditions to bolt connectors. Access the Reduce options in the command panels by clicking on Mode:Geometry -> Entity:Volume -> Action:Modify and using the dropdown to select Reduce.
                Meshing
                New Meshing Collapse Commands
                The following commands are good for collapsing low-quality tets and triangles. The user specifies a mesh entity to collapse and optionally a metric. The operation attempts to collapse the mesh entity, ensuring that the quality of surviving neighbor mesh entities does not degrade lower than the mesh entity being collapsed. The specified metric is used to determine quality. If not specified, “Scaled Jacobian” is used. If the collapse can not be done without degrading quality, no collapse is performed. To collapse triangles, use the first two commands. Only triangle and tets can be collapsed, not faces and hexes.
                Collapse Edge <id> [SCALED JACOBIAN | Aspect Ratio | Shape | Shape and Size]
                Collapse Tri <id> [SCALED JACOBIAN | Aspect Ratio | Shape | Shape and Size]
                Collapse Tet <id> [Altitude | Aspect Ratio | Aspect Ratio Gam | Distortion | Inradius | Jacobian | Normalized Inradius | Node Distance | SCALED JACOBIAN | Shape | Shape and Size | Timestep]
                Enhancements to Meshedit Command
                The [keep node] option indicates which node to collapse the edge to. The [compress_ids] option was also added to preserve the previous behavior of compressing the mesh id space after the collapse.
                 Meshedit Collapse Edge <id> [keep node <id>] [compress_ids]
                Mesh Intersection Group Naming
                A new option was added to the Find Mesh Intersection command to allow naming the group created containing the intersecting mesh. If no group name is specified, the group is named ‘mesh_intersect’ for 3D elements and ‘surf_intersect’ for 2D elements.
                Find Mesh Intersection {Block|Body|Surface|Volume} <id_list>> [with {Block|Body|Surface|Volume} <id_list>] [low <value=0.0001>] [high <value=0.0001>] [exhaustive] [worst <num_worst>] [draw] [log] [group <'name'>]
                Normalized Inradius Metric for tet10 Elements
                A new quality metric Normalized Inradius is now included as a standard option for all quality commands that affect tets and tris. It is intended to measure quality of TETRA10 and TRI6 elements, but can also measure linear (TETRA4, TRI3) elements. While most tet metrics, such as the default Shape, only take into account the 4 corner nodes of the tet, the Normalized Inradius uses the ten nodes of the tet. This is especially useful when measuring quality for a coarse tet mesh at curved surfaces where mid-edge-nodes can be projected to geometry distorting the elements. An example of using the new metric in a command to display the mesh quality is as follows:
                Quality Volume All Normalized Inradius Draw Mesh
                New Node Constraint Options
                When tet meshing with TETRA10 elements or setting a block element type to TETRA10, the mid-edge nodes on the surfaces can be projected to follow the geometry. In some cases, those projections can form an invalid or poor quality element when the linear version of the elements would otherwise be acceptable. Previously, CUBIT provided the set node constraint command to control mid-edge node projections. The SMART option allows for projections only if element quality does not degrade below a quality threshold. This version provides a new tet quality parameter and threshold parameter.
                Set Node Constraint \[on|off|SMART][tet quality [distortion|NORMALIZED INRADIUS]] [threshold <value=0.15>]
                With the introduction of the Normalized Inradius metric in this release, the tet quality setting can use this new metric as criteria for projecting mid-edge nodes. The new threshold value permits setting of a value at which mid-edge nodes will be straightened if the quality falls below. The node constraint options can also be set in the Options or Preferences dialog under Mesh Defaults and can be saved between CUBIT runs.
                Parallel Tetrahedral Meshing
                With this release, users have access to MeshGem’s parallel tet mesher, TetraHPC. Parallel tet meshing is an option in the Tet Mesh Command panel mentioned above. Parallel tet meshing is threaded and will support up to 8 concurrent threads.
                Geometry
                Reduce Command
                The reduce command prepares a bolt for analysis by quickly breaking down its geometry into its simplest form and applying boundary conditions. The different options allow the bolt to be simplified, decomposed into its component parts, overlap removed and fitted to surrounding geometry, imprinted and merged with surrounding geometry, meshed with a qtri scheme on the plug volume, and more. The full command syntax for the command is:
                Reduce {volume<ids>} [fit_volume] [webcut [{Head|Shank|BOTH}]]
                        [imprint] [merge][qtri] [increment_block_ids] [summary] [diameter <value>]
                        [group_id{<value>|Default}] [group_name {<string>|Default}]
                        [head_block_id{<value>|Default}] [head_block_name {<string>|Default}]
                        [shank_block_id{<value>|Default}][shank_block_name {|Default}]
                        [plug_block_id{<value>|Default}] [plug_block_name {<string>|Default}]
                        [bolt_block_id{<value>|Default}] [bolt_block_name {<string>|Default}]
                Groups Persist across Webcut
                When a volume or body of a group is split in a webcut operation, the resultant pieces of the webcut will also be in the group.
                Sculpt
                HTET Unstructured Option
                Sculpt now provides an option for splitting hexes into tets using an unstructured method where each hex is subdivided into six tets. Previously only the structured approach was available which split each hex into 24 tets.
                Thicken Void
                A new option for ensuring physical separation between elements of different material blocks is now provided. The new thicken_void option will insert elements designated as the void block material where non-void blocks would otherwise be in contact.
                Better Fitting STL
                Using the capture=5 option in Sculpt, mesh is fitted to the input STL. Sculpt now associates the grid edges of the reference mesh to the STL curve geometry. This is an extra level of association, in addition to the grid faces associated to the STL surface geometry. The result is better conforming of the mesh to the STL.
                Color Smoothing Improvement
                Color smoothing (spot optimization) in sculpt now extends smoothing out one additional layer of nodes after the first smoothing iteration, ensuring better quality.
                Graphics, Utilities, etc.
                Enhancements to Free Entity Selection
                The ability to select free surfaces (sheet bodies) has been added to the command:
                Select Free [surface <id_list>] [curve <id_list>] [vertex <id_list>] [add|remove]
                No More Highlight Color Collisions
                The automatic colors that CUBIT assigns to entities have been slightly changed to avoid colors that are too close to the highlight color, which previously made it difficult to see what was highlighted.
                Case Insensitive Names
                When naming entities in Cubit, names are now case insensitive.
                New HDF5 file type supported
                A new file type for saving the state of the Cubit model has been introduced in Cubit 2020.2. The new file type is .cub5. The contents and structure of the new type is exactly the same as a .trelis file, but the extension name has been changed. Beginning with Cubit 2020.2, users will be able to read in .trelis files, .cub5 files, and .cub files. Users will be able to export .cub files and .cub5 files, but they won’t be able to export .trelis files. Over time, Coreform Cubit will deprecate support for .trelis files in favor of supporting only .cub and .cub5 files.
                What are the motivations for this change?
                • The brand name Trelis is being discontinued. A file extension of .trelis will be confusing
                • Coreform Cubit and Sandia Cubit will continue to work towards aligning the two products more closely. Currently, Sandia Cubit does not support import and export of HDF5-based model files. Adding the .cub5 file extension will enable Sandia’s support of HDF5 model files in the future.
                • Coreform Cubit will continue to fully support the .cub file format. A .cub file is the non-HDF5, proprietary format used by Cubit. The .cub file is freely exchanged between Coreform Cubit and Sandia Cubit assuming the underlying versions of Cubit are equivalent.
                Defects Fixed in Coreform Cubit 2020.2
                2859 Draw curve all produces error on composited surface
                3103 Extended selection *.py files not showing up on Mac
                3485 Spurious warning on cub import
                3710 CUBIT™ slow to select with a long command string
                3791 Draw command outputs commands when nothing to draw
                4045 Dark mode on mac - model tree font matches the background color
                4065 Model tree needs refresh event after import
                4116 Crash - on merge all
                4117 Draw vol not is_meshed" produces ERROR if everything is meshed
                4158 Nastran Export Issue
                4310 Selecting free vertex, curves and surfaces with is_free
                4440 Crash in RelWithDebInfo mode on Windows
                4504 SAW client has flashing graphics on Windows
                4519 Case sensitivity not respected in new parser help strings
                4609 MGT Function
                4615 Unique_genesis_ids not working with import ‘filename.cub’
                4632 Change to fire ray output
                4646 Have an explicit option to name a new group
                4648 Bug with list geometry after volume regularization
                4691 Old attributes remain when importing cub file
                4694 Update get_total_bound_box documentation
                4695 Node moving (smoothing) bug in CUBIT™ 15.6
                4697 Bug with selecting entities in CUBIT™ 15.6
                4701 Group_names_ids() missing from documentation
                4703 Crash - get_sub_elements
                4737 Nastran exporter broken since 15.4
                4740 Segfault in CUBIT™ python module when importing an exodus database
                4743 Extraneous Command Output for volume copying
                4747 Add query for material types for all blocks in a CUBIT™ session
                4755 Update netcdf
                4768 Selection not recognised in batch mode
                4772 Python 3.7 with CUBIT™-alpha - error loading shared object
                4774 Draw command outputs commands when nothing to draw
                4786 Equivolume and equiangle unrecognized
                4787 Documentation update - Mesh Refinement
                4835 Bug in splitting surface using “close_to”
                4864 Typo when trying to export quality metric from a lite mesh
                4866 Crash - tetmeshing with MeshGems 2.11
                4959 Performance issue with recent merge of parser changes
                4974 Misplacement of higher-order mid-face nodes during smoothing
                Avoid generation of a new volume in surface removal on multiple shell volume
                ‘Simplify’ command respects vertices now. Not respected previously
                Hardlines can now be parsed with ‘num_parents=1’
                Ref # Description
                205 Can’t have return carriages within for loops in a CUBIT™ python script
                380 Keep volume in group after a webcut and reflections
                618 Exodus-based surface mesh sizing by function
                660 Select surface based on angle
                3528 Sierra mesh_scale to use more updated version of CUBIT™
                3535 Update CUBIT™ component snap shot in Sierra repository
                4627 Create standalone Sculpt CMake for Alegra
                STL import performance improvement
                Import Mesh-basd geometry performance improvement on models with large sidesets
                Enhanced meshing of composites. Better underlying faceting from ACIS
                Improved robustness in blunt tangency command
                ‘Topology check coincident node’ works off absolute distance instead of distance between bounding boxes
                Fix for inability to create group in quality command using ‘node distance’ metric
                Allowing blocks to persist through unite operation with ‘include_mesh’ option
                Support Dark Mode
                Add a command panel navigation method that minimizes wasted vertical space
                Other Enhancements to Coreform Cubit 2020.2
                Limitations Introduced in Coreform Cubit 2020.2
                Ref # Description
                3433 Superelement export not supported
                CUBIT™ is not supported on RHEL6 machines
