Power Tools GUI Tutorial Step 11
Step 11: Meshing the Model
Use the Mesh Power Tools to apply schemes to the remaining volumes.
- Press the Mesh Tools tab in the Power Tools window
- Press Analyze
All of the schemes have now been set with a sweeping algorithm. The model is ready to be meshed. All volumes should appear green in the graphics window.
- Toggle the Reset Graphics button to return volumes to their original colors
Select Volume as the entity, and Intervals as the Action.
- Enter all in the "Select Volumes" input window
- Select Constant Size from the list of sizing options
- Enter 2 for the size
- Press Apply Size
- Press Preview
The graphics window should appear as follows, with the mesh size increments highlighted on all of the curves in the model.
- Go to Mode - Meshing, Entity - Volume, Action - Mesh, and press the Mesh Button
There is no need to press the Apply Scheme button since the scheme have already been set in the Meshing Tools.
The final mesh should look like this:
Congratulations! You have just completed the Power Tools Tutorial. Click on the arrow to return to the Tutorial home.
