Coreform Cubit™ Help v2026.8
Tweaking Geometry
  • Tweaking Vertices
  • Tweaking Curves
  • Tweaking Surfaces
  • Tweak Remove Topology
  • Tweak Volume Bend
The tweaking commands modify models by moving, offsetting or replacing surfaces, curves, or volumes while extending the adjoining surfaces to fill the resulting gaps. This is useful for eliminating gaps between components, simplifying geometry or changing the dimensions of an object.
