Mesh Cutting
The term "mesh cutting" refers to modifying an existing mesh by moving nodes to a cutting entity and modifying the connectivity of the mesh so that the original mesh fits a new geometry. The behavior of mesh cutting is intended to be similar to web cutting in that the process results in a decomposition of the original geometry. The difference is that the decomposition is performed on meshed geometry and results in the creation of virtual geometry partitions. The underlying acis body remains unchanged. The user has the option to determine what is partitioned during mesh cutting: the volume, the surfaces only, or nothing.
The current scope of mesh cutting is limited to cutting hex meshed volumes with planes and extended surfaces. These cutting entities are also limited in that mesh cutting will not work if they pass through a vertex at the end of more than two curves. Mesh cutting does not work on tet meshes or surface meshes.
The steps of mesh cutting include:
- Create a starting mesh. This mesh is typically simpler than the desired final mesh and can be created with sweeping, mapping, or some other available meshing algorithm. Currently, the starting mesh must be a single volume: mesh cutting does not handle merged volumes or assemblies.
- Create a cutting entity that can be used to capture the new detail in the mesh. Currently, mesh cutting works with planes or sheets extended from surfaces. It is important to note that if an extended surface is used, mesh cutting will not capture any geometric features (curves or vertices) of the surface.
- Issue the command to cut the mesh. The meshcut commands are similar in syntax and behavior to the webcut commands.
The following entities with the associated commands are available for mesh cutting:
Coordinate Plane
A coordinate plane can be used to cut the model, and can optionally be offset a positive or negative distance from its position at the origin.
Meshcut Volume <range> Plane {xplane|yplane|zplane} [offset <dist>]
The planar surface to be used for mesh cutting can also be previewed using the Draw Plane command.
Planar Surface
An existing planar surface can also be used to cut the model.
Meshcut Volume <range> Plane Surface <surface_id>
Plane from 3 points
Any arbitrary planar surface can be used by specifying three nodes that define the plane.
Meshcut Volume <range> Plane Node <3_node_ids>
Extended Surface
An extended surface or "sheet" can also be used for mesh cutting. In this case, the sheet is not restricted to be planar and will be extended in all directions possible. When cutting with an extended surface mesh cutting will ignore all curves and vertices of the surface. Also, the resolution of the mesh will determine how well curved surfaces are captured with meshcutting. A surface with high curvature will not be captured accurately with a coarse mesh. Note that some spline surfaces are limited in extent and may not give an expected result from mesh cutting.
Meshcut Volume <range> Sheet [Extended From] Surface <surface_id>
Note: When cutting with surfaces extended from composite surfaces the default underlying surface approximation may result in a poor final mesh for mesh cutting. This problem can be fixed using the following command:
Composite closest_pt surface <id> gme
See the discussion on composite geometry for a more detailed description of this command.
Meshcut Options
The following options can be used with all the meshcut commands:
[PARTITION VOLUME|partition surface|no_partition]: By default, mesh cutting will create virtual partitions of the volume being cut to match the cutting entity. This option allows mesh cutting to also create only the surface partitions or create no partitions for the volume or surfaces.
[no_refine]: This option tells mesh cutting not to refine the mesh around the cutting entity.
[no_smooth]: This option tells mesh cutting not to perform the final smoothing step after the cut has been made.
Meshcutting Scope
The following is a list of the current scope and limitations of meshcutting.
- Meshcutting only works on hex meshes.
- Meshcutting only works for single volumes. It currently does not handle assembly meshes.
- Currently, only planes and extended surfaces can be used as the cutting entity.
- Curves and vertices on the cutting entity will not be captured in the mesh.
- Meshcutting will not work if the cutting entity passes through a meshed vertex that is at the end of more than two curves.
- The resolution of the mesh determines how well a non-planar cutting entity will be captured in the resulting mesh. Small features and high curvature will not be captured by a coarse mesh.
- Spline surfaces are limited in extent and may not give expected results if used as an extended cutting surface.
Meshcutting Example
The figures below show an example of mesh cutting. Figure 1 shows the body that will be meshed. This body is a brick with intersecting through-holes. The steps to create a mesh for this body are listed below.
Figure 1: The original, unmeshed body
Step 1: Create a starting mesh. Figure 2 below shows the starting mesh for this problem. The commands for this mesh are:
cubit> reset
cubit> set dev on
cubit> create brick x 10
cubit> create cylinder radius 3 z 15
cubit> subtract 2 from 1
cubit> volume 1 scheme sweep
cubit> volume 1 size .75
cubit> webcut volume 1 with plane xplane offset 0
cubit> merge all
cubit> mesh volume 1 3
Figure 2: The starting mesh
Step 2: Create a cutting entity. Figure 3 shows the volume that will be used to cut the mesh. The commands are:
cubit> create cylinder radius 2 z 15
cubit> rotate volume 4 about x angle 90
Figure 3: The starting mesh and cutting entity
Step 3: Cut the mesh. Figure 4 shows the new mesh after the original mesh has been cut. Also recommend smoothing the mesh:
cubit> meshcut vol 1 3 sheet surface
27
cubit> surf in vol 1 3 smooth sch condition number beta 2 cpu
0.5
cubit> smooth surface in volume 1 3
cubit> vol 1 3 smooth scheme condition number beta 2 cpu
0.5
cubit> smooth volume 1 3
cubit> draw volume 1 3
Figure 4: The mesh after meshcutting
Step 4: Final step. Figure 5 shows the quality of the final mesh. The command is:
cubit> quality volume 1 3 scaled jacobian
global draw mesh
Figure 5: Quality of final mesh
