Example 3. Webcutting using the sweep option
This example introduces additional webcutting options. This example would be a simple many-to-one sweep except for the overhanging lip and the protrusions on the bottom surface. To a beginner user, it may at first seem reasonable to use the bottom surface as a webcutting plane. However, this will not create a many-to-one sweepable volume. Instead, you need to use the protruding surfaces as cutting planes, and extend them through the entire volume.
Suggested webcuts
| Webcut | Command |
CUBIT> webcut volume 1 with sheet extended from surface 27 |
CUBIT> webcut volume 1 with plane surface 30 |
CUBIT> webcut vol all sweep surf 26 vector -1 0 0 through_all Now Volume 3 (red) has only 1 target surface. CUBIT> imprint all |
Final mesh
The final mesh is created at a size of 0.05 for all volumes.
