Sculpt Mesh Transformation
Sculpt options for applying transformations to the mesh following mesh generation. For cases where the initial geometry description may not be at the desired scale or bounds, the transformation options provide the ability to apply transformations to the node locations following the mesh generation procedure. This can be effective for microstructure models, where the size and location may be defined by the given intervals of the data.
Mesh Transformation -tfm --transform --xtranslate -xtr <arg> Translate final mesh coordinates in X --ytranslate -ytr <arg> Translate final mesh coordinates in Y --ztranslate -ztr <arg> Translate final mesh coordinates in Z --xscale -xsc <arg> Scale final mesh coordinates in X --yscale -ysc <arg> Scale final mesh coordinates in Y --zscale -zsc <arg> Scale final mesh coordinates in Z Sculpt Command Summary
Translate Mesh Coordinates in X
Command: xtranslate Translate final mesh coordinates in X Input file command: xtranslate <arg> Command line options: -xtr <arg> Argument Type: floating point valueCommand Description:
Translate all mesh coordinates written to Exodus file by X delta distance.
Translate Mesh Coordinates in Y
Command: ytranslate Translate final mesh coordinates in Y Input file command: ytranslate <arg> Command line options: -ytr <arg> Argument Type: floating point valueCommand Description:
Translate all mesh coordinates written to Exodus file by Y delta distance.
Translate Mesh Coordinates in Z
Command: ztranslate Translate final mesh coordinates in Z Input file command: ztranslate <arg> Command line options: -ztr <arg> Argument Type: floating point valueCommand Description:
Translate all mesh coordinates written to Exodus file by Z delta distance.
Scale X Mesh Coordinates
Command: xscale Scale final mesh coordinates in X Input file command: xscale <arg> Command line options: -xsc <arg> Argument Type: floating point valueCommand Description:
Scale all mesh X coordinates written to Exodus file by given factor
Scale Y Mesh Coordinates
Command: yscale Scale final mesh coordinates in Y Input file command: yscale <arg> Command line options: -ysc <arg> Argument Type: floating point valueCommand Description:
Scale all mesh Y coordinates written to Exodus file by given factor
Scale Z Mesh Coordinates
Command: zscale Scale final mesh coordinates in Z Input file command: zscale <arg> Command line options: -zsc <arg> Argument Type: floating point valueCommand Description:
Scale all mesh Z coordinates written to Exodus file by given factor
