Periodic Intervals
The number of intervals on a periodic surface, such as a cylinder, in the dimension that is not represented by a curve is usually set implicitly by the surface size.
However, periodic intervals and firmness can be specified explicitly by the following commands:
Surface <range> Periodic Interval <intervals>
Surface <range> Periodic Interval {Default|Soft|Hard}
