Web Cutting Options
The following options can be used with all web cut commands:
[NOIMPRINT|Imprint [include_neighbors] ]: In its default implementation, web cutting results in the pieces not being imprinted on one another; this option forces the code to imprint the pieces after web cutting. The include_neighbors option will also imprint adjacent bodies.
[NOMERGE|Merge]: By default, the pieces resulting from an imprint are manifold; specifying this option results in a merge check for all surfaces in the pieces resulting from the web cut.
[Group_results]: The various pieces resulting from the previous command are placed into a group named `webcut_group'.
[Preview]: This option will preview the web cutting plane without executing the command.
