Split Periodic Surfaces
Solids which contain periodic surfaces include cylinders, torii and spheres. Splitting periodic surfaces can in some cases simplify meshing, and will result in curves and surfaces being added to the volume. The command used to split periodic surfaces is:
Split Periodic Body <id_range|all>
This command splits all periodic surfaces in a body or bodies.
