Removing Curves
At times you may find that you have an extraneous sliver/short curves in your model. The following command detects curves having a length less than the supplied lengthlimit in the specified bodies or volumes and replaces them with vertices. If no lenghtlimit is specified, a default value of 0.001 is used.
Remove Sliver Curve {Body|Volume} <id_range> [lengthlimit <double>] [Exclude Curve <id_range>]
It is recommended that curves approaching the size of features in the model not be remove with this command, only those substantially smaller, so as to preserve model integrity. For larger curves, try regularizing or compositing. The Exclude Curve option prevents specified curves from getting removed. Lengthlimit default = 0.001.
