Blunt Tangency
The blunt tangency commands are used to eliminate small angles in the model caused by fillets. The operation 'blunts' the tangency, or small angle, using two different approaches. The first replaces the tangency with a pair of surfaces, essentially moving the vertex to a location with a larger angle. The second approach creates a surface with a larger radius through a tweak operation, increasing the sharp angle at the vertex.
Blunt tangency vertex <id> [remove_material] [composite] [angle <value>] [depth <value>] [preview]
Blunt tangency tweak vertex <ids> [angle <value>] [offset surface <id>] [tolerance <value>] [preview]
As shown in Figure 1, the depth parameter controls the depth of the surfaces that replace the tangency, while the angle parameter controls the resultant angle of the new tangency. Figure 2 demonstrates the behavior of the remove_material option which removes material instead of adding it.
Figure 1. Blunt Tangency Operation
Figure 2. Remove Material Option
The composite option will composite the surfaces created in the blunt tangency operation with the adjacent larger surface, from which they were cut out. See figure 3.
Figure 3. Blunt Tangency with Composite Option. Highlighted surface is resulting composite surface.
The second form of the command replaces the surface with the radius at the vertex with a larger radius surface, increasing the angle. The command tweaks the surface that results in the least amount of material removed (Figure 4) or added (Figure 5). The angle option works the same as in the first form of the command. The offset surface option specifies which surface is tweaked (offset), as sometimes the surface that results in the smallest material added/removed is not correct. The tolerance option prevents small curves from being created, snapping to adjacent vertices within the tolerance (Figure 6) or possibly modifying an adjacent surface (Figure 7).
Figure 4. Blunt Tangency Tweak -- Material Removed
Figure 5. Blunt Tangency Tweak -- Material Added
Figure 6. Blunt Tangency Tweak -- Tolerance
Figure 7. Blunt Tangency Tweak -- Tolerance
