Entity Names
By default, geometric entities in CUBIT are referenced using an entity type (e.g. Surface, Volume) and an id, for example "draw surface 1".  However, geometric entities can also be assigned names, to simplify working with specific entities.  Once a name is assigned to an entity, that name can be used in any CUBIT command in place of the entity type and number.  For example, if surface 1 were named 'mysurf1', the command above would be equivalent to "draw mysurf1".  Also, since entity names are saved with the geometry, this also provides a means for persistent identifiers for geometric entities.   Names can be added or removed using the following commands.
{Group|Body|Volume|Surface|Curve|Vertex} {Name | Rename} {`<entity_name>'| Default}
{Group|Body|Volume|Surface|Curve|Vertex} Remove Name {`<entity_name>'| All | Default}
The name of each topological entity appears in the output of the List command. In addition, topological entities can be labeled with their names (see label command). A list of all names currently assigned and their corresponding entity type and id (optionally filtered by entity type) can be obtained with the command
List Names [{Group|Body|Volume|Surface|Curve|Vertex|All}]
Notes:
  • In a merge operation, the surviving entity is given the name(s) of the deleted entity.
  • A geometric entity may have multiple names, but a particular name may only refer to a single entity.
Case-Insensitive Names
Entity names in CUBIT are case-insensitive. This means that there is no difference between the name 'mysurf1' and MySurf1'. The case of names will be preserved as assigned. For example, a volume named 'MyVolume' will display the name 'MyVolume' but can be referenced by any case version of the name, 'MYVOLUME', 'mYvOlume', etc. Case-sensitivity can be toggled on/off with the command:
[Set] Case Sensitive Names [on|OFF]
Valid and Invalid Names
Although any string may be used as an entity name, only valid names may be used directly in commands. A name is valid if it begins with a letter or underscore ("_"), followed by any combination of zero or more letters, digits, or the characters ".", "_", ":", or "@". If an attempt is made to assign an invalid name to an entity, CUBIT will generate a valid version of the invalid name by replacing invalid characters with an underscore. Then both the valid and invalid versions of the name are assigned to the entity. For example, assigning the name "123#" to a volume will result in the volume having two names, "123#" and "_23_". The valid name can be used directly in commands (mesh _23_), while the invalid name can only be referenced using a longer, less direct syntax (mesh volume with name "123#").
Reconciling Duplicate Names
When an attempt is made to assign the same name to two different entities, a suffix is added to the name of the second entity to make it unique. The suffix consists of the "@" character followed by one or more letters or numbers. For example, the following commands will result in volumes 1 to 3 having the names "hinge", "hinge@A", and "hinge@B", respectively:
volume 1 name "hinge"
volume 2 name "hinge"
volume 3 name "hinge"
To prevent this automatic "fixing" of names, the Fix Duplicate Names flag may be switched to off. If the user attempts to assign a duplicate name while the flag is set to off, the name will remain unchanged.
Set Fix Duplicate Names [ON|Off]
Automatic Name Creation
CUBIT provides an option for automatically assigning names to entities upon entity creation.  This option is controlled with the command:
Set Default Names {On|OFF}
When this option is on, entities are assigned default names consisting of a geometry type concatenated with the entity id, for example 'cur1', 'surf26', or 'vol62'.
CUBIT automatically propagates names through webcuts. If an entity that has been assigned the name "Gear" is split through webcuts, the resulting bodies are named "Gear" and "Gear@A". Try the following example.
br x 10
volume 1 name "Cube"
webcut volume 1 xplane
webcut volume 1 2 yplane
webcut volume 1 2 3 4 zplane
label volume name
Figure 1. Name Propagation through Webcuts
You can operate on these propagated names using wildcards such as:
mesh volume with name 'Cube*'
block 1 volume with name 'Cube*'
Applying Namespaces to Entities
The namespace command adds options to prepend entity names with a namespace using "::" as a separator. The following namespace commands are available:
  • namespace push "<name>" - Add a namespace to the stack.
  • namespace pop - Remove the top namespace in the stack.
  • namespace "<current_name> rename "<new_name>"" - Rename all namespace instances on geometry
  • namespace "<name>" strip - Remove the given namespace from all geometry
  • list namespace - list the namespaces on the stack
  • clear namespace - clear the stack
The namespace on the top of the stack is prepended if an entity has a n existing name. All newly created entities will have the namespace applied. This is especially useful for tracking newly created entities in a webcut. For example,
brick x 1 volume 1 name 'part' namespace push 'left' webcut volume 1 plane xplane
The new volume 2 will be named left::part.
If the process is continued as follows:
namespace push 'top' webcut vol all plane yplane
The two newly created volumes will be named top::part and top::left::part respectively. If a user wants to determine the ids of the newly created objects they can use a command such as
list volume with name "top*" ids
Geometry that has duplicate names will continue to be suffixed with an '@' and characters as previously.
Using namespaces in conjunction with setting automatic name creation help identify lower dimensional entities by the namespace and can be used to track results through operations. For example:
set default names on
brick x 10
volume 1 name 'hole'
namespace push 'hole'
cylinder radius 2 z 12
# named hole::vol2 subtract volume 1 from volume 2
list surface with first_name "hole*"
# the hole surface is named hole::sur7
Naming Merged Entities
When entities that have the same base name, such as "platform" and "platform@A", are merged, the resulting entities is assigned both names. The set merge base names on command tells Cubit that in this situation, it should merge the names too. The command syntax is:
Set Merge Base Names [On|OFF]
For example:
brick x 10
vol 1 copy move 10
surf 6 name 'platform'
surf 10 name 'platform'
Surface 10 actually is named platform@A, since we don't want duplicate names
merge all
list surf 6
You see that surface 6 has both 'platform' and 'platform@A' as names. Now, for the contrasting example
brick x 10
vol 1 copy move 10
merge all
list surf 6
You see that surface 6 has only 'platform' as its name.
