Location, Direction and Axis Specification
- Specifying a Location
- Specifying a Location on a Curve
- Specifying a Direction
- Specifying an Axis
- Specifying a Plane
- Drawing a Location, Direction, or Axis
Many commands require that a location or a direction be
specified. Although entering the three floating point numbers
required to uniquely define a vector is perfectly acceptable, it
may be more convenient to specify the direction or location with
respect to existing entities in the model.
For example, the following commands might be used for creating
straight curves using location and direction specification
described here:
Create Curve [From] Location {options} Location {options}
Create Curve [From] Location {options} Direction {options} Length <val>
