Key Press Commands for the GUI
Several commands have a key press shortcut. These commands will be executed with respect to the currently selected entities; see the following table:
Shortcut Key
Command
l |
List information about the current entity to the output window. |
i |
Toggle the visibility of the selected entity (make invisible or visible). |
e |
Echo entity id to command line. |
Select the next entity. |
Select the previous entity. |
0 |
Toggle picking of vertices. |
1 |
Toggle picking of curves. |
2 |
Toggle picking of surfaces. |
3 |
Toggle picking of volumes. |
4 |
Toggle picking of groups. |
Toggle picking of mesh nodes |
Toggle picking of mesh edges. |
Toggle picking of mesh faces. |
Toggle picking of mesh hexes. |
F5 |
Refresh graphics window |
Activate/inactivate graphics clipping plane |
